11-05-2010 02:56 AM
Does anybody know if, when using LMS4, it's needed to register the applications in ACS as it was in earlier versions? I know the new version doesn't use the same application scheme as the old one, but I'd like to make sure. I guess this is done now using the built in Role Management setup, right?
Thanks in advance.
Pablo.
Solved! Go to Solution.
11-05-2010 04:36 AM
No, you are correct, it is not needed anymore to register LMS applications with ACS to get RBAC (role based access control) in LMS; the authorization is now part of LMS itself;
while it is not necessary, you can still use ACS for authentication (amongst some other mechanisms)
the general overview (Local Users):
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/admin/security.html#wp1134795
about Role Management Setup (where you can assign LMS Tasks to a Role)
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/admin/security.html#wp1100379
11-05-2010 04:36 AM
11-08-2010 01:12 AM
coolness!! thanks for your anwer, and thanks for the links you sent me, they're very accurate about what I needed.
Cheers!!
P.
