CW2K > Netconfig > script/template for enabling ssh ??
jason.aarons
Customer has 130 3550 switches, 170 APs and 50 Routers (12.2T). They want to run a netconfig job to enable ssh everywhere. Can this be done? Is there a netconfig template for this? The key generation usually comes backs requesting input, etc.
NW-DC-RAS1(config)#crypto key generate rsa
The name for the keys will be: router1.local.lan
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]:
and sometimes the device already has a key (you don't see this via a show running-config)
% You already have RSA keys defined named NW-DC-RAS1.stellarishealth.net.
% Do you really want to replace them? [yes/no]:
jason.aarons
I should clarify all devices are SSH capable, already have the correct K9 IOS loaded, it just needs to be turned on everywhere.
You don't mention your CW2K version or OS, but RME 3.5, IDU 9 on W2K, has a SSH Template for IOS devices.
It asks for Hostname/Domain Name/No. of Key Bits/SSH Timeout/No.of Authentication Retries
Unfortunately, it would appear all devices would have to have the same hostname. Unless you could wild-card it or somehow have it grab the existing hostname.
