01-03-2020 12:58 AM
Hi all,
I'm struggling to find the correct dashlet on Cisco Prime to show the bandwidth usage by internal IP ? Is this possible as i keep just getting the WAN interface IP on there and not which internal IP is using what bandwidth ?
01-03-2020 04:47 AM
Do you have netflow enabled to send the information to Prime ?
01-03-2020 05:19 AM
Yes, although i'm not sure how to see if this is actually collecting the information in the first place ?
