Dashlet for finding WAN utilization by IP
WonderfulIT
Hi all,
I'm struggling to find the correct dashlet on Cisco Prime to show the bandwidth usage by internal IP ? Is this possible as i keep just getting the WAN interface IP on there and not which internal IP is using what bandwidth ?
balaji.bandi
Do you have netflow enabled to send the information to Prime ?
BB
Yes, although i'm not sure how to see if this is actually collecting the information in the first place ?
