Deleted Flash
sthelens5
Community Member
Ive accidentally deleted the flash memory in a 1700 series router? How do I get it back?
spremkumar
Level 11
Level 11
hi
have you executed squeeze command or only delete command ? if you have done only with the delete command try using undelete command to recover them.
But if you have done with squeeze command then you wont be able to recover the deleted file..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hcf_r/cfn_11h.htm#wp1033799
regds
