Design software on No. of swtiches/routers and other components in new setup
Rockk
Hello Team,
Is there a designing software on how many switches/routers/VPN/FW/etc. needed when we are setting up new IT infra.
Kindly advise.
marce1000
 - The question is too broadened and also depends on the company size such as number of users, factory/production  needs, and others. A simplified answer starts here :
               https://www.cisco.com/c/en/us/products/switches/switch-selector.html
M.
Thanks Marce. We have quite big plant and need to establish network management and IPsec tunnel to connect Cloud applications.
Do you suggest any, Please.
 - I know it's not a direct-path-answer, but the best solution I feel , is to always work with a reseller, plan meetings , ask advice , make a plan  , and then invest and implement .  We work with Dimension Data.
M.
