Cisco Prime OVA Hardware Requirements
MikeO5422
Beginner
Beginner
Cisco had listed hardware requirements to support various install versions on a virtual machine. I specifically want to try the device compliance feature, but I am barely using the required resources for the express install. For compliance the standard version is required, which brings the required hardware to something ridiculous given that I am barely making express sweat. So, my question is, can I enable compliance on express or is it it acceptable to install the standard version on less powerful hardware than what is recommended. I just want the feature....
Jurgens L
Participant
Participant
Hi There,
The problem you will have is if you don’t follow Cisco’s recommendations and you do run into trouble even if it is related to other issues and you log a TAC, Cisco will point out that you are not following the requirements and therefore you will first need to address that.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
Recognize Your Peers
