06-13-2007 11:27 AM
my Device Discovery status "Running" all the time. I would like to stop it to change the Discovery settings. as for now, it didn't let me update the change.
06-13-2007 11:30 AM
Please provide your discovery.log and NMSROOT/campus/etc/cwsi/DeviceDiscovery.properties.
06-13-2007 11:40 AM
06-13-2007 11:47 AM
You're hitting a very old bug in Campus Manager. You should consider upgrading to LMS 2.6. In the meantime, run:
NMSROOT/bin/pdterm DeviceDiscovery
Then edit DeviceDiscovery.properties, and change the default*Cmty lines to:
snmp.defaultReadCmty=public
snmp.defaultWriteCmty=private
Now you will be able to make your changes, and restart DeviceDiscovery.
06-13-2007 11:54 AM
Is LMS 2.6 free upgrade? because my support was expire, and I am waiting for the new the contract.
06-13-2007 11:56 AM
Yes. You have to go to LMS 2.5.1 first, then 2.6. Both are free and downloadable from http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml .
06-13-2007 12:40 PM
what type of training do I need in-order to know all this? :). I took the Implementing ciscowork, but most the time was, clicking the mouse. Do you have free online source?
06-13-2007 12:46 PM
The only comprehensive training solution I know of for LMS is from our training partner Ascolta (http://www.ascolta.com). However, that is not free.
06-14-2007 12:52 AM
I find the Application tutorials very helpful to get an overview of the apps and a detailed look on special tasks
follow this link:
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/index.html
select the desired app, choose 'Presentation' under 'Product Literature'in the new window - there you?ll find the tutorial
