Device Discovery Problem LMS Version 4.0
stephan.brunst
I have installed the new version lms 4.0 (Windows 2008 - no R2 ) and I have a big problem regarding device discovery with this version
The devices are prepared for SNMPv2c and I start the discovery over the module CDP with seed devices and the right SNMP settings.
The devices are reachable but I can't find the new devices in the DCR.
In the status display I can see only Devices in the "Devices are updated in DCR" counter. Many devices are displayed with "localhost".
I use a public DNS Server for internet access only but I adjusted the lmshosts file on the local host for local use.
What can be the problem?
Many thanks
Nael Mohammad
Level 5
Level 5
1. What kind of seed device are you using?
2. Did you verify if the snmp read/write credentials are correct?
3. Are you able to ping and snmpwalk to the device from the LMS server?
4. Go to Admin --> System --> Debug Settings --> Discovery Logging Configuration --> and select the follow modules:
  • CSDiscovery Adapter
  • Credentials Module
  • Discovery Modules (All)
  • System Module
5. Select Apply and re-run discovery job.
6. After completion, get the following logs:
  • NMSRoot\log\CSDiscovery.log
  • CSDiscovery-config.xml and system-config.xml from NMSRoot\conf\csdiscovery
I had modified the Windows Hosts file and then worked the Discovery
