Device not responding
chrisayres
Level 4
Level 4
What does
"Check DB status (running/stopped). Check DB tables for missing or NULL key value columns."
mean when a device is not responding to CW2000 RME inventory
Regards Chris Ayres
ebreniz
Level 11
Level 11
This happens with some of the hardware equipments,
The workaround is to reload the equipment and attempt to add the router/equipment into inventory.
