05-11-2011 07:49 AM
Is there a Cisco Works Device Package for the new 3750X switches? Just bought
159 3750X-48PS-S switches to go with over 1000 3750G switches.
05-12-2011 06:32 AM
Sorry, not yet. This page lists all currently supported devices
05-13-2011 01:18 AM
LMS 3.2 doesnt support the device out of the box but I downloaded a device update for the software download section for the 3750x which got it working in ciscoview. Believe this was the update i used for ciscoview. Probably an update for the other parts of LMS as well.
05-13-2011 06:02 AM
Thanks for the correction - I missed them when checking my earlier post.
3750X's ARE on both the LMS3.2 support list and the LMS4.0 / 4.01 support lists.
As you mentioned, applying the latest device support package will add them to the fold.
