Device package update with RME 4.3 in LMS2.5 for Catalyst 2960 support.
cperroquin
I'm currently triing to update my device packages in RME to add support for Catalyst 2960.
I download those 4 files :
Cat2960.RME40.v1-0.zip
LibInventory.RME40.v1-5.zip
SharedInventoryCatIOS.RME40.v1-3.zip
SharedSwim2900XL.RME40.v1-3.zip
SharedSwimIOS.RME40.v1-4.zip
Then I arrived to the device package update screen (see picture attached).
If I tried to update the 5 packages together, the system ackownledge.
Then the services stop and restart.
But the upgrade is not done.
When I go back to the device package update screen, there's no change.
And the 2960 is not supported by the RME.
If I do the upgrade one by one same result.
Martin Ermel
Have you installed the December Update for LMS 2.5 (SP 3) and MDF 1.7 before? The squence for installing the packages is:
LibInventory
SharedSwimIOS
SharedSwim2900XL
Cat2960
HTH,
MArtin
