device warranty details in LMS 3.2
arun
Can we maintain device warranty details in LMS 3.2 if so where it can be. Please help. Thanks in advance
Joe Clarke
You could add such parameters to the DCR user-defined fields under Common Services > Device and Credentials > Device Management.  Edit the credentials for the devices, and add any warranty details in the user-defined fields.  You can add additional fields as well as rename the fields under Common Services > Device and Credentials > Admin > User Defined Fields.
