DeviceDiscovery Process In Transient Terminated
dholder
Was having problem starting device discovery in Campus Manager. After looking at a couple of different things, noticed that DeviceDiscovery is in TRANSIENT TERMINATED ProcessState.
Has anyone ran into this before?
I have updated software to latest and greatest.
Thanks in advance for helping the hopeless.
David Holder
Resurrection HealthCare
22 Replies 22
Thanks I will do that.
i have exactly the same issue - using:-
CiscoWorks Common Services 3.0.4
Campus Manager 4.0.4
CiscoView 6.1.4
Device Fault Manager 2.0.4
Internetwork Performance Monitor 2.6.0
Integration Utility 1.6.0
Resource Manager Essentials 4.0.4
is there a fix or workaround for this?
thanks
andy
you can try replacing your corrupt file by doing the following:
1. stop the daemon manager
2. rename DeviceDiscovery.properties to DeviceDiscovery.properties.old,then
copy DeviceDiscovery.properties.orig, and rename it
3. restart daemons
4. check, and configure your snmp and discovery settings and run a discovery
thanks for the reply
i tried this earlier without success.
discovery/snmp settings all look ok but when i run a discovery, the status returns to idle within seconds (usually takes ~30 seconds) - the results show one device which Campus Manager says is unreachable. is the ANI database corrupt? how can you restore to original settings (i'm currently evaluating Cisco LMS so the data isn't to important)
To reinit the ANI database you would run the following from the command line:
/CSCOpx/bin
reinitdb.pl -restore
If you are showing one device as unreachable then its more than likely that you have connectivity or snmp problems getting to that seed device.
Can you ping the device? How about snmpwalk from the NMS station?
ran reinitdb.pl -restore (it was in folder \CSCOpx\campus\bin) - when i started up ciscoworks and went to campus manager every device had disappearred except the 1 device in the results for device discovery (this was before i had even started a discovery).
i'll try an snmpwalk and get back to you
device is snmp reachable. i've reinstalled all the Ciscoworks apps but device discovery stiil doesn't work.
discovery log details
2006/05/04 09:49:27 main ERROR SMFFactoryLoader: java.lang.NullPointerException
2006/05/04 09:49:27 main ERROR DiscoveryMain: AniStaticConfigException: Error accessing devices--root path , packageName com.cisco.nm.ani.server.devices
devicediscovery log details
MESSAGE DiscoveryMain: Properties will be read from e:\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
DiscoveryMain: file name is e:\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
DiscoveryMain: Loading mib values...complete
DiscoveryMain: Loading communities values...complete
FATAL ERROR ServiceModule: undefined property: ServiceModuleList
process report details
Process Name State
UTMajorAcquisition Never started
EDS-TR Never started
FHPurgeTask Never started
DFMCTMStartup Administrator has shut down this server
DeviceDiscovery Transient terminated
DataPurge Administrator has shut down this server
ANIServer Running with busy flag set
any advice appreciated
I would suggest that you open a TAC case to further troubleshoot this
