Devices steel in learning mode in DFM
ocaron
Windows 2003 R2
LMS 3.2
DFM 3.2.0
CM 5.2.1
RME 4.3.1
All my device steel in learning mode.
Also I have this error on the page DFM - Device Management - Device Import - Auto Allocation
Error in getting instance of TreeGenerator class
com.cisco.nm.trx.kdm.utils.DcrGroupSelectorTreeGenerator
Root Cause:com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
Is the fully-qualified hostname, 5VA-VAL-A5TR503.valcartier.mil.ca resolvable on this server?  That is, what output do you get for:
NMSROOT/bin/perl NMSROOT/bin/resolver.pl 5VA-VAL-A5TR503.valcartier.mil.ca
16 Replies 16
Joe Clarke
First, try rebooting the server.  This will rule out a process state issue.  If the problem persists, post the output of the pdshow command.
This is the post you want.
We use a static IP for the server and the SNMP works well for RME and CM.
Did you do the reboot?  Is the problem persisting after the reboot?
Hello
I just reboot the server again and the problem persist.
Here again the pdshow
Post the NMSROOT/objects/smarts/local/logs/DFM.log and DFM1.log as well as any error messages you see in the Windows Event Viewer.
This the posts
Also I noticed for a while, in my CM windows.  I have no jobs in the completed job.
But in CS and RME jobs are presents.
May be my problem is upstream of DFM ?
Post the DFMOGSServer.log, and the output of the command:
NMSROOT/objects/smarts/bin/brcontrol
The posts
Your the man.
Thanks alot.
The problem came because this server is not in the same domain of the main network.
Michel Hegeraat
Level 7
Level 7
I got exactly the same error message.
It went away when I could use a static IP address for the LMS server.
My devices however did move to the 'known' state.
If they remain learning at 10% it often means that there is an SNMP connectivity issue.
Cheers,
Michel
May be the problem is during the process of CM.  I don't know.
It's seem that the process between RME and CM is OK.  But from CM to DFM ....
I post the pdshow and I will wait from the answer of mister Clarke.
To helping you to understand the problem.
I try to change the poling configuration in DFM and I received this message.
Could not retrieve current data since the PTMServer process is down.
Please restart the process and perform this operation again.
But the PTMServer is running
Peter_Setaffy
Hallo
I have also the problem.
This is my version LMS:
LMS 2.5
CiscoWorks Common Services 3.0.3
Campus Manager 4.0.3
CiscoView 6.1.2
Device Fault Manager 2.0.3
Integration Utility 1.6.0
Resource Manager Essentials 4.0.3
Can someone help me?
thanks
