DFM Error witch LMS 3.1
seba
Hello I'm having the same error mentioned by other users.
High Severity Alerts show this message:
An exception occurred.Please check the  AAD.log file for further details.
The message in AAD.log is this:
18-feb-2010|14:35:24.135|ERROR|AAD|TP-Processor3|OGSInteractor|getOGSGroupMembers|.|com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
Attached you can find pdshow output
6 Replies 6
Joe Clarke
If you have waited at least 30 minutes since starting Daemon Manager, and this problem persists, post the DFMOGSServer.log.
It's been that way for days.
Thank you
There are no fatal errors here.  Post the NMSROOT/objects/smarts/local/logs/DFM.log and DFM1.log.
Both files were empty. I've restarted de server and they are still empty. I've attached .bak files
Try rebooting the system.
Hello
It didn't work. Finally I reinstalled LMS 3.2 from scratch.
Thank you
