DHCP discover
eXPlosion
I have a router 2811, and PC connected to fa0/1. It cannot receive ip address from router. It should receive from pool 50 (vlan50).
Patg#sh run
Building configuration...
Current configuration : 1693 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Patg
enable secret 5 $1$mERr$/jJFQNiaJSPg5O/2VYM/n777
enable password asdfghj
ip dhcp pool 10
network 192.168.50.0 255.255.255.192
ip dhcp pool 20
network 192.168.50.64 255.255.255.192
ip dhcp pool 30
network 192.168.50.128 255.255.255.192
ip dhcp pool 40
network 192.168.50.192 255.255.255.192
ip dhcp pool 50
network 192.150.50.0 255.255.255.192
no ip cef
no ipv6 cef
ip name-server 192.168.50.100
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 10 native
ip address 192.168.50.1 255.255.255.192
interface FastEthernet0/0.2
encapsulation dot1Q 20
ip address 192.168.50.65 255.255.255.192
interface FastEthernet0/0.3
encapsulation dot1Q 30
ip address 192.168.50.129 255.255.255.192
interface FastEthernet0/0.4
encapsulation dot1Q 40
ip address 192.168.50.193 255.255.255.192
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 50
ip address 192.150.50.99 255.255.255.192
interface Serial1/0
no ip address
clock rate 2000000
shutdown
interface Serial1/1
no ip address
clock rate 2000000
shutdown
interface Serial1/2
no ip address
clock rate 2000000
shutdown
interface Serial1/3
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
password asdfghj
login
end
7 Replies 7
Seb Rupik
Hi there,
you have created a sub-interface on fa0/1 and tagging the frames with the VLAN 50 ID. it is very likely that the PC connected to this interface will not be configured for tagged frames and will drop them.
The solution is to configure the interface without the VLAN tags:
no interface FastEthernet0/1.1
However the more scalable solution would be to connect a Layer2 switch to Fa0/1 and configure a trunk port connected back to Fa0/1. Then create an access port on the switch for VLAN 50 and connect the PC to it.
cheers,
Seb.
Actually this was done on port fa0/0. Fa0/0 has connected Cisco switch. But the dhcp OFFER only passes to trunk and not vlan10 on switch, where the PC is connected.
I mean there is another PC connected to switch, which has trunk to router f0/0 port.
balaji.bandi
you need to configure on router respected port as Trunk port
router example :
interface fa 0/0
switchport trunk allowed vlan all  (if you want only 50 you can add only 50)
On the Switch side : ( VLAN 50 create)
interface fas 0/0 -- change here respected interface.
Pc connected port
interface fas 0/2 -- change the real port
switchport mode access
switchport access vlan 50
no shutdown all ports and check all ports up and running.
test and advise.
BB
Router interface has no ability to be switchport interface. It should have subinterfaces an be a router on a stick.
jcockburn
Hi Mate,
Seems like the Interface is not in the same IP subnet as the pool...
Take a look at that
Ciao
JC
I changed and router cfg looks
router:
ip dhcp pool 50
Computer is on interface:
ip address 192.150.50.32 255.255.255.192
But still not getting ip
Hello
From this original configuration, the switchport connecting to this rtr fa0/0 interface need to be a trunk and have it native vlan set to 10.
RTR
default interface FastEthernet0/1
interface FastEthernet0/0.5
ip dhcp pool 10
default-router 192.168.50.1
lease 0 8
ip dhcp pool 20
default-router 192.168.50.65
lease 0 8
ip dhcp pool 30
default-router 192.168.50.129
lease 0 8
ip dhcp pool 40
default-router 192.168.50.193
lease 0 8
ip dhcp pool 50
default-router 192.150.50.99
lease 0 8
Switch
no ip routing
int x/x
description facing rtr
switchport mode trunk
switchport trunk native vlan 10
exit
vlan10-50
exit
int x/x
description pc
switchport host
Kind Regards
Paul
