DHCP on VLANs
SamuelBarata
Hi, I'm trying to set up DHCP on 3 VLANs
#show ip dhcp pool
Pool vlan2 :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 1022
Leased addresses : 0
Pending event : none
1 subnet is currently in the pool :
Current index      IP address range                             Leased addresses
10.2.80.1           10.2.80.1             - 10.2.83.254      0
The other dhcp pools for the other 2 vlans are set up the same way
When I run `ip dhcp` on a VPC (connected to any interface on f1/5 - f1/15 on Sw11) and I get a "Can't find dhcp server"
show ip dhcp statistics
on SwR10 does not show any DHCP requests received
What am I missing in the router configuration?
version 12.4
no service dhcp
hostname SwR10
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip dhcp use class
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 10.2.80.1 10.2.80.99
ip dhcp excluded-address 10.3.80.1 10.3.80.99
ip dhcp excluded-address 10.4.80.1 10.4.80.99
ip dhcp pool vlan2
   network 10.2.80.0 255.255.252.0
   default-router 10.2.80.9
ip dhcp pool vlan3
   network 10.3.80.0 255.255.252.0
   default-router 10.3.80.9
ip dhcp pool vlan4
   network 10.4.80.0 255.255.252.0
   default-router 10.4.80.10
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vtp file nvram:vlan.dat
ip tcp synwait-time 5
interface FastEthernet0/0
 description *** Unused for Layer2 EtherSwitch ***
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet1/0
 switchport mode trunk
 duplex full
 speed 100
interface FastEthernet1/1
 duplex full
 speed 100
interface FastEthernet1/2
 duplex full
 speed 100
interface FastEthernet1/3
 duplex full
 speed 100
interface FastEthernet1/4
 duplex full
 speed 100
interface FastEthernet1/5
 switchport access vlan 2
 duplex full
 speed 100
interface FastEthernet1/6
 duplex full
 speed 100
interface FastEthernet1/7
 duplex full
 speed 100
interface FastEthernet1/8
 duplex full
 speed 100
interface FastEthernet1/9
 switchport access vlan 3
 duplex full
 speed 100
interface FastEthernet1/10
 duplex full
 speed 100
interface FastEthernet1/11
 duplex full
 speed 100
interface FastEthernet1/12
 duplex full
 speed 100
interface FastEthernet1/13
 switchport access vlan 4
 duplex full
 speed 100
interface FastEthernet1/14
 duplex full
 speed 100
interface FastEthernet1/15
 duplex full
 speed 100
interface Vlan1
 ip address 10.1.80.10 255.255.252.0
interface Vlan2
 ip address 10.2.80.10 255.255.252.0
interface Vlan3
 ip address 10.3.80.10 255.255.252.0
interface Vlan4
 ip address 10.4.80.10 255.255.252.0
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
banner exec
This is a normal Router with a SW module inside (NM-16ESW)
It has been preconfigured with hard coded speed and duplex
To create vlans use the command "vlan database" from exec mode
After creating all desired vlans use "exit" to apply the config
To view existing vlans use the command "show vlan-switch brief"
Warning: You are using an old IOS image for this router.
Please update the IOS to enable the "macro" command!
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
version 12.4
no service dhcp
hostname Sw11
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip routing
no ip cef
no ip domain lookup
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
interface Vlan1
 no ip address
 no ip route-cache
interface Vlan2
 no ip address
interface Vlan3
 no ip address
interface Vlan4
 no ip address
no ip http server
control-plane
banner exec
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
In the config that is posted in the original post I see this
no service dhcp
which would certainly explain why DHCP is not working.
Rick
5 Replies 5
SamuelBarata
balaji.bandi
what missing in the configuration ? what we need to ask you to share the config, so we can verify what is missing here.
looks like you have DHCP helper address missing here. high level, we need more information to address correctly
what are the vlan ?
what vlan working ?
what vlan not working ?
what is the address svi configured for that vlan ?
show run for all the device help us to guide correct direction.
BB
updated question
the switches interfaces 5-15 are on access mode on different VLANs
and 1-5 on trunk mode
balaji.bandi
Not sure what VPC not getting the IP address, can you give us vpc no getting IP and what port connected.
if the device connected access port - the config should be accessport - there is no need to have Trunk config
Example config as below :
switchport mode access switchport access vlan 3 duplex full speed 100
BB
no service dhcp
Rick
