Differnece Between NTP trust key 1 and Trust key 12
As both trust-key are using the MD5 encryption. what is major Between NTP trust key 1 and Trust key 12. have tried to use the trust key 12 instead of trust key 1. but I could not see that NTP SYN.
5 Replies 5
Ntp trust-key number
This is only number it not meaning anything.
You can choose key 12 but you need config
ntp authentication-key 12 md5 xxxx
Shall i use the Hash value or password for authentication.
After md5 use clear text password.
MHM
@DEBADURLAV SARANGI hi its the key number to refer in your NTP authentication settings. you can have many keys and refer relevant key in authentication command.
Good luck
KB
When you configure NTP you can have multiple keys configured on the device. For instance say you have three NTP servers that you want to authenticate with, however, each server has a different authentication key. In that case the key ID would be a key component because it will be referenced in the configuration for each of those server. Here is an example:
ntp authentication-key 1 md5 password-one
ntp authentication-key 2 md5 password-two
ntp authentication-key 3 md5 password-three
ntp server 1.1.1.1 key 1
ntp server 2.2.2.2 key 2
ntp server 3.3.3.3 key 3
However, if you have multiple keys configured on the device and all the NTP servers use the same key, in that case you can just configure the NTP trusted key without specifying the key ID for each server similar to this, let's say you want to use key ID 2 for all of them:
ntp trusted-key 2
ntp server 2.2.2.2
ntp server 3.3.3.3
Finally, the value you add after the "md5" keyword is text that will then be converted into an MD5 hash value, so you don't have to put the already converted hash value, the device will use the value you type as a seed attribute for MD5 hash. It is different than when you configure a password on the device and you select the encryption type, in that case you would need to insert the encrypted value rather than the clear text password.
