Discovery devices with loopback
b.bersier
Hello, I did clean the device database and restart a discovery into CS using loopback.
Everything was ok, replication into RME with OK et the inventory ok.
This morning the ips were back again ( a discovery run during the night ) into CS et RME.
How can I do it to keep it ?
Thank's for you help.
Blaise
Nael Mohammad
Level 5
Level 5
It sounds like you need to modify and save the discovery settings to discover by loopback.  Here is a good document to read written by Joe Clarke that discusses this in detail. https://supportforums.cisco.com/docs/DOC-9005#Configuring_CSDiscovery
Post the  CSCOpx/conf/csdiscovery/CSDiscovery-config.xml file, then we can take a look at your settings.
