05-05-2013 06:04 AM
I've browsed around to the other support strings to make sure I didn't miss anything, but I can't seem to get this to work. I have the latest sl_suspend_ports.tcl and tm_suspend_ports.tcl created by Joseph Clarke from strings that verified they worked as planned. Here are the commands I issued to register the scripts -
Directory of flash:/policies/
9 -rwx 3101 May 3 2013 07:58:03 +00:00 sl_suspend_ports.tcl
10 -rwx 4669 May 3 2013 07:58:44 +00:00 tm_suspend_ports.tcl
conf t
event manager directory user policy flash:/policies
event manager policy sl_suspend_ports.tcl
event manager environment suspend_ports_days 1
event manager environment suspend_ports_config flash:/susp_ports.dat
event manager policy tm_suspend_ports.tcl
#show run | inc event manager environment
It doesn't appear to work though. Essentially, we have a need to make sure all computers are always on and all ports not active for >24 hours to be shutdown and moved to a designated vlan (I added the 'lappend' statement to the script to specify the additional command of assigning the vlan)
I'm running 12.2(55)SE7 on Catalyst 3560s and 3750s
Is there a way to manually run the script? Did I miss anything in the configuration?
Thanks for your help!
Chris
Solved! Go to Solution.
12-15-2015 07:02 AM
These are EEM Tcl policies and not tclsh scripts. It looks like you're trying to run them through tclsh when you need to be registering them as EEM policies.
12-15-2015 05:19 PM
Okay, I might have misunderstood a little bit there since they are .tcl extensions. In my configurations, I have the following:
event manager directory user policy "flash:/policies/suspend_ports"
event manager session cli username "STW"
While my directories show:
Directory of flash:/policies/suspend_ports
9 -rwx 3101 Mar 2 1993 06:11:45 +00:00 sl_suspend_ports.tcl
10 -rwx 4552 Mar 1 1993 12:29:36 +00:00 tm_suspend_ports.tcl
I am not using a radius server quite just yet. Right now I'm just trying to get it to implement on a test switch that just uses a local username/password. I'm getting no results from the EEM.
12-16-2015 07:57 AM
You've configured it correctly. If the susp_ports.dat file is not being created and/or the down ports are not being shutdown, I suggest you open a new thread under http://www.cisco.com/go/ciscobeyond for help. This thread has gotten unwieldy.
02-23-2016 08:10 AM
Joe,
This is what I currently have:
set cli [concat $cli [list "interface $port" "shut" "switchport access vlan XXX" "description Script Generated Shutdown"]]
I am wanting to retain the original description to the port and add the rest of the description "script generated shutdown" to it. I have tried to use a $description as shown below but get errors:
set cli [concat $cli [list "interface $port" "shut" "switchport access vlan XXX" "description $description Script Generated Shutdown"]]
Thank you for your assistance.
02-23-2016 08:23 AM
You need to extract the description first. You can do that from the output of "show int". For example:
set output [run_cli [list "show int $port | inc Description:"]]
regexp {Description: ([^\r]+)} $output -> description
Then you can use $description
02-23-2016 10:38 AM
Thanks for the information. I put this into my script and it now only shutdowns that interface only and not the others. This is how I implemented it.
set cli [list "config t"]
foreach port [array name suspend_ports] {
set output [run cli [list "show int $port switchport | inc Access Mode VLAN"]]
set output [run cli [list "show int $port | inc Description:"]]
if { ! [regexp {Access Mode VLAN: NUM} $output] && ! [regexp {Access Mode VLAN: NUM} $output] && [regexp {Description: ([^\r]+)} $output -> Description]} {
set cli [concat $cli [list "interface $port" "shut" "switchport access vlan xxx" "Description $Description Script Generated Shutdown"]]
action_syslog msg "Shutting down port $port since it was last used on [clock format $suspend_ports($port)]"
I cannot figure out how to get this to work. Thanks.
02-23-2016 10:45 AM
Your reusing $output before you process it. Try this:
set output [run_cli [list "show int $port switchport | inc Access Mode VLAN" "show int $port | inc Description:"]]
Then change your if to:
if { ! [regexp {Access Mode VLAN: NUM} $output] && ! [regexp {Access Mode VLAN: NUM} $output] } {
02-23-2016 11:11 AM
This is what I have now:
When I run this I get the following error:
can't read "Description": no such variable while executing "list "interface $port" shut" "switchport access vlan xxx" "Description $Description Script Generated Shutdown""
02-23-2016 12:06 PM
Add a conditional for Description:
if { ! [regexp {Description: ([^\r]+)} $output -> Description] } {
set Description {}
02-24-2016 06:35 AM
I still get the same error.
if{!regexp {Description: ([^\r]+)} $output -> Description] } {
set Description {}
02-24-2016 07:06 AM
There is a type here. Your condition should be:
if{! [regexp {Description: ([^\r]+)} $output -> Description] } {
set Description {}
02-24-2016 10:22 AM
Thanks for letting me know about the typo. It still didn't work the way I had it before so this is what I did and now it is working, sort of. I notice that it does not keep the description that each port had the same. It over writes it sometimes with the same description over multiple interfaces. For example:
interface G1/0/1 Description 2000
Interface G1/0/2 Description 4000
After the script runs it puts this:
interface G1/0/1 Description 2000 Script Generated Shutdown
Interface G1/0/2 Description 2000 Script Generated Shutdown
This is how the code looks like now:
set Description {}
if{![regexp {Description: ([^\r]+)} $output -> Description] } {
09-25-2017 02:04 PM
I have an issue with tm_suspendports_tcl logging-where the error log is growing to over 10mg and corrupting the ios. Is there a way to limit the size of the error log file and keeping the a+ append file attribute?
Thank you,
Tom
