EEM applet not trigers
adir868
Frequent Visitor
Frequent Visitor
I'm trying to configure on Nexus 9000 EEM Scripting by matching on syslog pattern.
the syslog is about interface is down, this is the syslog i get when there is violation - %ETHPORT-5-IF_DOWN_LINK_FAILURE
and what I'm configured:
event manager applet port-shut
event syslog pattern '%ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/3 is down'
action 1 cli line "enable"
action 2 cli line "Configure terminal"
action 3 cli line "Interface Ethernet1/3"
action 4 cli line "shut"
action 5 cli line "end"
action 6 cli line "exit"
action 7 syslog msg “Interface Eth1/3 will be Disabled by script"
When I recommend disconnecting the interface the Triger is not working, I can see the %ETHPORT-5-IF_DOWN_LINK_FAILURE in logs but the EEM scripting is not working. What am I doing wrong?
balaji.bandi
try with " quote :
event syslog pattern "%ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/3 is down"
is the nexus have AAA config then you need use authorisation bypass
Try run manually
event manager run port-shut
BB
