EEM cron timer running at hh:00 minute
Hi People,
Recently I have been testing a custom EEM script which runs every 15minutes and checks some CLI output and does some action.
I have a cron timer set using the following line:
event timer cron cron-entry "3,18,33,48, * * * *"
To my knowledge this is only supposed to run at those specified minutes of the hour (3, 18, 33, 48) but it is also running at minute 0 of every hour.
E.g. with the script:
event manager applet TEST_NAME authorization bypass
action 10 cli command "enable"
---some actions---
I am seeing in my logs the following:
*Apr 12 16:00:00: %HA_EM-6-LOG: TEST_NAME : DEBUG(cli_lib) : : CTL : cli_open called.
*Apr 12 16:00:00: %HA_EM-6-LOG: TEST_NAME : DEBUG(cli_lib) : : OUT : Router>
*Apr 12 16:00:00: %HA_EM-6-LOG: TEST_NAME : DEBUG(cli_lib) : : IN : Router>enable
Is this expected behaviour for the EEM to run at minute 0? Can I prevent this from happening?
Thanks in advance.
2 Accepted Solutions
balaji.bandi
Look at the syntax to use for cron.  - should be good "3,18,33,48"
https://crontab.guru/
BB
Seb Rupik
Hi there,
Remove the final comma from your minute value list. I assume IOS is assuming there is another value, and in its absence using a zero. The cron timer should be:
event timer cron cron-entry "3,18,33,48 * * * *"
cheers,
Seb.
balaji.bandi
BB
Seb Rupik
Hi there,
cheers,
Seb.
Thank you both for the answers, I will amend my cron line.
