tftp using management interface on ws-c4500x-32 switch
sdavids5670
Level 2
Level 2
I'm trying to load a license file onto a WS-C4500X-32 switch by using tftp but I'm running into an issue.  The only IP address on the switch right now is associated with the Fa1 interface which is on a non-default vrf called mgmtVrf.  While I can ping my tftp server using the following command:
ping vrf mgmtVrf 172.19.30.96
Sending 5, 100-byte ICMP Echos to 172.19.30.96, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
I cannot communicate with the tftp server to retrieve the license file.  This command:
copy tftp://172.19.30.96/licensefile.lic bootflash:
Results in:
%Error opening tftp://172.19.30.96/licensefile.lic (Timed out)
Is there a way to get this switch to use the mgmtVrf for tftp or do I need to configure another L3 interface on this switch?
Here's the configuration of my Fa1 interface:
interface FastEthernet1
vrf forwarding mgmtVrf
ip address 172.21.2.30 255.255.255.0
speed auto
duplex auto
end
Here's my routing table:
HQ-4500X-SW1#show ip route vrf mgmtVrf
Routing Table: mgmtVrf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 172.21.2.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 172.21.2.1
      172.21.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.21.2.0/24 is directly connected, FastEthernet1
L        172.21.2.30/32 is directly connected, FastEthernet1
And here's a traceroute to the tftp server just to prove that I'm not making this up:
HQ-4500X-SW1#traceroute vrf mgmtVrf 172.19.30.96
Tracing the route to 172.19.30.96
VRF info: (vrf in name/id, vrf out name/id)
  1 172.21.2.1 0 msec 0 msec 4 msec
  2 172.21.1.17 0 msec 0 msec 0 msec
  3 172.21.1.34 0 msec
    172.21.1.30 0 msec 0 msec
  4 172.19.30.96 0 msec 0 msec *
Steven
Hi Steven,
have  you tried to set Fa1 as the TFTP source interface:
(config)# ip tftp source-interface FastEthernet1
Rolf
7 Replies 7
Sandeep Choudhary
Try the following:
1- Make sure the TFTP is pinging
2- Try using TFTPD32 software for TFTP
3- Check if there is any firewall issue or tftp application on the computer
4- Make sure your TFTP server is turned on.
5- Check the file extension, If possbile copy the exact file extension from TFTP server file .
Hope it helps.
The tftp server I'm using is working.  I use it just about every day.  It works with all of the other switches/routers in my environment.  I definitely think this has to do with the management vrf that the 4500X is using.  Unless I can tell the switch to use the mgmtVrf VRF for tftp I don't think this is going to work.  I think it's just not connecting because it doesn't have an interface in the default vrf.  When I fire up packet capture on my tftp server I never see packets from the switch.
Hi Steven,
Rolf
OMG (hangs head in shame)!   I was looking for something like that but I can't believe I didn't try that.  Works like a champ.  Thanks!
I am having the exact same issue but that command did not work for me.
rarae
For anyone who is still experiencing an issue:
The solution that worked for me was adding " vrf mgmtVrf" to the end of the tftp command. This requires you to do everything in one line: #copy tftp://<URL> bootflash: vrf mgmtVrf
Hope this is helpful!
I have the same problem and this command doesn't work on IOS XE , do you know how to use VRF in copy command in IOS XE?
