EEM no longer functions
ISSOintraining!
Upgraded a 5000 series switch from 7.3.1 to 7.3.2 and now a previously successful tftp backup eem fails to run and the error message reads: cisco eem_policy_dir policy expired. I can run the backup command by itself and it works. This is not a lot of information but does anyone have any experience of why an applet stops running after an upgrade?
balaji.bandi
i have not seen this issue with any of the code upgrade.
what will be the outcome  - if you remove the EEM applet config and re-apply ?
or run some debug, see what failing ? (do you see any attempt at remote end ?)
is this remote end SCP / TFTP or SFTP or FTP ?
BB
do you see the policy when you issue the command:
show event manager policy registered
