EEM on port error-disable due to UDLD
Leo Laohoo
I would like to ask from the EEM community for some assistance in regards to crafting an EEM script for an ME-3800X.  We have one or two appliances whereby the only uplink (TenGigabitEthernet0/1 and/or TenGigabitEthernet0/2) goes into error-disable and caused by UDLD.  What I am looking for is a script to do the following:
1.  If the ports TenGigabitEthernet0/1 and/or TenGigabitEthernet0/2 goes into error-disable caused by UDLD or link-flap then disable the port, wait for 5 seconds, enable the port;
2.  Wait for 15 seconds and send an email.
I only want this EEM to work on the TenGigabitEthernet interfaces and I do not want the EEM script to do this on the access ports.
Error-disable recovery is a global option and there's no option to limit on a per-interface level.
Thank you in advance.
For this, an applet like the following should work:
event manager applet udld-recover
 event syslog pattern "Te0/[12], unidirectional link detected" maxrun 50
 action 1.0 regexp "(Te0/[12])," $_syslog_msg match intf
 action 2.0 cli command "enable"
 action 3.0 cli command "udld reset"
 action 4.0 wait 30
 action 5.0 mail from "user@example.com" to "user@example.com" subject "UDLD Reset" server "10.1.1.1" body "UDLD has been reset after $intf when err-disable"
Joe Clarke
What syslog message is generated when the ports go into err-disable.
Thanks for responding, Joe.
We were not able to take down the error messages but I believe they error messages could be:
%UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Te0/2, unidirectional link detected
%PM-4-ERR_DISABLE: udld error detected on Te0/2, putting Te0/2 in err-disable state
Could an EEM script be created when an error message or an event of "unidirectional link detected" occurs, do the following:
1.  In privilege mode, issue the command "udld reset".
2.  Wait for 30 seconds and then send an email.
Thanks for your assistance and support, Joe.
 action 4.0 wait 30
Thanks, Joe.
I'm going to check this out.
