EEM - problem with generate outputs
Could you help me with this problem
- Data
> IOS 12.4(15)T13
- EEM config
CONFIG-SET
event manager applet TEST trap
event syslog pattern "%SYS-5-CONFIG_I:"
action 1.0 cli command "enable"
action 2.0 cli command "sh run"
action 3.0 mail server "192.168.1.146" to "engineer@cisco.com" from "devtest@cisco.com" subject "B25 PBX Alert" body "$_cli_result"
- Debug output
OUTPUT-SET
Rack1R1#debug event manager all
All possible Embedded Event Manager debugging has been turned on
Rack1R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Rack1R1(config)#^Z
Rack1R1#
*Mar  1 23:51:34.346: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Mar  1 23:51:34.350: check_eem_cli_policy_handler: command_string=configure terminal
*Mar  1 23:51:34.350: check_eem_cli_policy_handler: num_matches = 0, response_code = 1
*Mar  1 23:51:35.354: %SYS-5-CONFIG_I: Configured from console by console
*Mar  1 23:51:35.362: fh_fd_syslog_event_match: num_matches = 1
*Mar  1 23:51:35.362: fh_fd_data_syslog: num_matches = 1
*Mar  1 23:51:35.366: fh_send_server_sig_hndlr: received a pulse from Syslog Event Detector on node0/0 with fdid: 2
*Mar  1 23:51:35.370: fh_send_syslog_fd_msg: msg_type=62
*Mar  1 23:51:35.370: fh_send_syslog_fd_msg: sval=0
*Mar  1 23:51:35.370: fh_send_server_sig_hndlr: received FH_MSG_EVENT_PUBLISH
*Mar  1 23:51:35.374: fh_schedule_callback: fh_schedule_callback: cc=66B81EDC prev_epc=0; epc=676B600C
*Mar  1 23:51:35.390: fh_schedule_callback: EEM callback policy TEST has been scheduled to run
Rack1R1#
*Mar  1 23:51:35.406: fh_io_msg: received FH_MSG_API_INIT; jobid=14, processid=230, client=4, job name=EEM Callback Thread
*Mar  1 23:51:35.406: fh_server: fh_io_msg: received msg FH_MSG_EVENT_REQINFO from client 4 pclient 1
*Mar  1 23:51:35.422: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_open called.
*Mar  1 23:51:35.430: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Rack1R1>
*Mar  1 23:51:35.430: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : Rack1R1>enable
*Mar  1 23:51:35.430: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Mar  1 23:51:35.430: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Rack1R1#
*Mar  1 23:51:35.510: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Rack1R1#
*Mar  1 23:51:35.510: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : IN  : Rack1R1#sh run
*Mar  1 23:51:35.514: cli_history_entry_add: free_hist_list size=0, hist_list size=7
*Mar  1 23:51:35.514: eem_no_scan flag set, skipping scan of command_string=check_eem_cli_policy_handler
Rack1R1#
*Mar  1 23:51:40.226: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Building configuration...
*Mar  1 23:51:40.226: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : Current configuration : 2710 bytes
*Mar  1 23:51:40.226: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : !
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : version 12.4
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : service timestamps debug datetime msec
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : service timestamps log datetime msec
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : no service password-encryption
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : !
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : hostname Rack1R1
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : boot-start-marker
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : boot-end-marker
*Mar  1 23:51:40.230: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : enable password cisco
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : !
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : no aaa new-model
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : memory-size iomem 5
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : OUT : ip cef
*Mar  1 23:51:40.234: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : 20+ lines read from cli, debug output truncated
*Mar  1 23:51:40.234: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: _cli_r
*Mar  1 23:51:40.234: %HA_EM-3-FMPD_ERROR: Error executing applet TEST statement 3.0
*Mar  1 23:51:40.238: %HA_EM-6-LOG: TEST : DEBUG(cli_lib) : : CTL : cli_close called.
*Mar  1 23:51:40.242: fh_server: fh_io_msg: received msg FH_MSG_CALLBACK_DONE from client 4 pclient 1
*Mar  1 23:51:40.242: fh_io_msg: EEM callback policy TEST has ended with abnormal exit status of 0xFFFFFFFF
*Mar  1 23:51:40.242: fh_schedule_callback: fh_schedule_callback: cc=66B81EDC prev_epc=676B600C; epc=0
*Mar  1 23:51:40.242: fh_schedule_policy: prev_epc=0x00000000; epc=0x00000000
*Mar  1 23:51:40.250: fh_server: fh_io_msg: received msg FH_MSG_API_CLOSE from client 4 pclient 1
*Mar  1 23:51:40.254: fh_io_msg: received FH_MSG_API_CLOSE client=4
- Problem
> How generate more than 20 lines output?
Joe Clarke
The debug output will never show more than 20 lines.  However, the email you receive will have the entire output.  The $_cli_result variable will contain the entire output of "show run".
Joe Clarke
Yes it is true. I checked it with configured email server.
Thank you for your help.
