EEM script to stop running on reload
pingduck
I have an EEM script that is triggered by interface down event. However, I found out that the event is triggered also when I issue the router reloads. There is no point running the script if reload is in progress. What is the best practice to detect the reload is in progress?
balaji.bandi
Post the EEM Script and Event to check
BB
event manager applet myapplet
event tag 1 track 10 state down
event tag 2 counter name tunnel1down entry-val 1 entry-op ge exit-val 1 exit-op ge
event tag 3 timer cron cron-entry "@reboot"
trigger
  correlate event 1 or event 2 or event 3
action 1 track read 10
action 2 counter name "tunnel1down" op set value 0
action 3 if $_track_state eq "down"
action 4  puts "Do something!"
action 5  wait 10
action 6  counter name "tunnel1down" op inc value 1
action 8 end
I think I would need an additional check in action 3 to make sure router is not in a "winding down" state. What is a good check?
