EEM to tftp copy code snippets to running config
jschweng
is it possible to use EEM to copy code snippets from tftp server to the runnign config =- i'm trying to do this but no joy so far
event manager applet CHANGE-IGMP
event none
action 1.0 cli command "enable"
action 1.1 cli command "copy tftp://192.160.11/SNIPPET1.txt system:running.config" pattern "running.config"
action 1.2 exit 1
yjdabear
It seems to me that it may simply need another line between actions 1.1 and 1.2 to respond to the prompt, something along the lines of:
action 1.2 cli command "y"
action 1.3 exit 1
hey that worked - thanks
I was trying to do that with the pattern response but it still didn't take it
it works except that you have to use the pattern statement and put
  "running-config"
in the command for the response to the copy
thank you for gettting me by that
Joe Clarke
yjdabear had the answer, but you really shouldn't be using "exit 1" in this policy.  You should just remove that action unless you mean to tell the EEM server that the policy did not complete successfully.
Additionally, if you configure "file prompt quiet" in the running config, many file operations will not longer be interactive, and you will not have to use the pattern syntax.
