EEM using syslog on Nexus
ambi
Is the syslog as an EEM event supported in Nexus
I am trying to run an EEM applet based on a syslog but unable to.
What i want is to shutdown a particular module when a power supply on the 7K is switched off .. possible?
Ambi
Thomas Masters
Check this out, looks like a pretty good doc with ideas for EEM on the 7k and it has a method to pattern match syslog
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_eem_events_and_examples.html#wp1024660
For some reason i am not able to get syslog as an option under event .. the only option i get is sysmgr
Any feature to be enabled before that ??
Ambi
