EEM
gornication
Level 2
Level 2
Hello!
event manager applet test
   event cli pattern "show vlan id 777" sync yes/sync no skip no/sync no skip yes
   action 1.0 puts "vlan 777"
Always get the same result:
cisco-test#show vlan id 777
vlan 777
Why?
How does this relate to exit status?
Of course I read something, but I didn't understand much. For example this: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/command/eem-cr-book/eem-cr-e1.html
balaji.bandi
What exactly your goal or trying to achieve here using EEM Script? - explain so we can assist better.
BB
The main goal is to understand how Event Manager works.
Here it is not clear to me why nothing changes after changes in the event manager applet configuration.
I expect that sync yes will lead to the fact that I see first the output of the command "show vlan id 777" and then "vlan777".
If sync no + skip no, then I will first see "vlan 777", and then the output of the command to which the manager reacted.
And if sync no + sync yes, then I will only see "vlan 777" after entering the command.
But that doesn't happen.
