EHWIC-4G-LTE-V MIB
jason crockett
Does anyone know if there is a MIB available for the EHWIC-4G-LTE-V card that would allow me to monitor the current RSSI level?
If I issue the command "show cell 0/1/0 radio" on my Cisco2911 router, I get the following info. I'd like to monitor the "Current RSSI" level in Solarwinds.
Router>show cell 0/1/0 radio
Radio power mode = ON
Current RSSI = -67 dBm
LTE Technology Preference = AUTO
LTE Technology Selected = LTE
The cisco-WAN-3G mib worked for me before this newest IOS of 15.2(4)M2 I'm using 15.1(4)M4 and able able to get SS from device.
Get signal Strength
.1.3.6.1.4.1.9.9.661.1.3.4.1.1.1.18
Get phone #
.1.3.6.1.4.1.9.9.661.1.3.1.1.4.18
Get SIM
.1.3.6.1.4.1.9.9.661.1.3.1.1.3.18
Get IMEI
.1.3.6.1.4.1.9.9.661.1.3.1.1.2.18
Roaming status
.1.3.6.1.4.1.9.9.661.1.1.1.6.18
1 unknown, 2 roaming, 3 home
9 Replies 9
Josh Potter
I've been looking at the MIBs and haven't been able this either, but I'm very interseted.
I got it by swapping the 18 for 29 on 15.4:
.1.3.6.1.4.1.9.9.661.1.3.4.1.1.1.29
SNMPv2-SMI::enterprises.9.9.661.1.3.4.1.1.1.29 = INTEGER: -49
Get signal Strength
Get phone #
Get SIM
Get IMEI
Roaming status
Thank you Daniel. I will give this a shot.
let me know if i can assist.
Josh Potter
No dice on 15.3.  I'll try falling back to 15.1 to see if that work.  Thanks for sharing those Daniel.
I got it working on 15.1(4)M4, as well. Next step is creating alerts based off the results of the custom poller. Thanks Daniel!
Same, I went back to 15.1 and it was working.  For our mobile "network in a box" I'm going to create an arduino based microcontroller to does SNMP polls and then displays the RSSI on a small LCD dispaly for remote users to see.
Reverting back to 15.1 isn't possible anymore.  Cisco doesn't support the LTE cards with newer firmware on 15.1.  I had to move to 15.2 and am now unable to monitor RSSI.  Anyone find a way to get this value via SNMP on 15.2 yet?
