09-05-2023 06:40 AM
I need to establish an EIGRP session between two L3 switches, one with three VRF and the second with just vlan interfaces.
I need the second switch can see all the ips on the second switch (the one with VRF).
09-05-2023 07:10 AM
As long as on the switch SVI Layer 3 have right config and other side VRF with right tag vlan - they should able to form the peers.
if you want to other VRF need to know the routes come from Switch - then you need leak to global vrf and learn from other VRF
below exmaple give you some direction :
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/200158-Configure-Route-Leaking-between-Global-a.html
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/216541-vrf-configuration-examples-on-ios-xe.html
BB
Log in to Community
