Embedded Syslog Manager and Configuration Management
Cory Anderson
Hi All,
I'm looking for a solution to send configuration related logs to a separate syslog server. One syslog server would get all logs, the other would get filtered logs.
All devices have the following config as part of the baseline:
archive
 log config
 logging enable
 logging size 200
 hidekeys
 notify syslog
 Do I need ESM, or is there a more simple solution out there from the device itself?
Mark Elsen
                          - This thread presents a solution based on ESM :
               https://community.cisco.com/t5/network-management/send-certain-syslog-messages-to-different-syslog-servers/td-p/2247930
 Not sure if it could work for your case , but personally I would for instance use 2 'full' syslog servers for redundancy ,and look for the configuration-changes with scripting solutions (e.g.)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
I use simple send logs to syslog as below :
logging host x.x.x.x ( x.x.x.x where your syslog IP address)
still you like to use your exsiting config you can use as below :
logging buffered 256000
archive log config logging enable logging size 200 hidekeys notify syslog contenttype plaintext
BB
