06-12-2019 08:52 AM - edited 06-12-2019 08:58 AM
Hi, I want to be able to install apps on the IR829 but i'm unable to reach the IoX local manager at https://192.168.2.2:8443 which is the Vlan1 interface.. I'm connected to the router via my laptop for initial testing to prove i can access the IoX console.
Here's my current config:
IR800#show run Building configuration... Current configuration : 5008 bytes ! ! Last configuration change at 16:15:55 UTC Wed Jun 12 2019 ! version 15.8 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname IR800 ! boot-start-marker boot-end-marker ! ! ! aaa new-model ! ! aaa authentication login default local ! ! ! ! ! aaa session-id common service-module wlan-ap 0 bootimage autonomous ! ignition off-timer 900 ! ignition undervoltage threshold 11 ! no ignition enable ! ! ! ! ! ! ! ! ! ! ! ! ip dhcp excluded-address 192.168.1.1 192.168.1.5 ! ip dhcp pool gospool network 192.168.1.0 255.255.255.0 dns-server 64.104.123.144 default-router 192.168.1.1 ! ! ! ip domain name cisco.com ip name-server 8.8.8.8 ip cef no ipv6 cef ! multilink bundle-name authenticated ! ! ! chat-script lte "" "AT!CALL" TIMEOUT 20 "OK" ! crypto pki trustpoint TP-self-signed-422713650 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-422713650 revocation-check none rsakeypair TP-self-signed-422713650 ! ! crypto pki certificate chain TP-self-signed-422713650 certificate self-signed 01 30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030 30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274 69666963 6174652D 34323237 31333635 30301E17 0D313930 36313231 31313332 355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F 532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3432 32373133 36353030 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100 D015FA7B 66C97D36 8235893E 0BC55840 28BA2652 7B2D966C 1E521301 EB105477 69FCFD73 52692D6F 67CA1088 A16524DE 92D16D7C AAB11361 DB597512 4697CCFD 18C09A09 119BB5B1 041F3897 C1FA2720 B659EE2B 8291F547 A0537FFB CCC0CD12 13D13B51 42122BE1 9D549906 46F2B160 956EF57D FFFF2B7A 7F978074 79373C79 02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D 23041830 1680149D 7ABE7F04 A6BD3835 23276B51 26C6A194 EAD8FC30 1D060355 1D0E0416 04149D7A BE7F04A6 BD383523 276B5126 C6A194EA D8FC300D 06092A86 4886F70D 01010505 00038181 000847BE 562A0F75 B33444EE CB4D4445 F4CD4B9E 2CB1DA21 AC691560 A6E6E488 41801026 2016559C A6C6B9C0 820E6774 0B4CAEC9 4348655C 08044DB2 5E47F770 07330947 63946EF3 2E0DF252 6E927593 FCE78531 0BF2D0FF 85659F58 A11A1D7C 18D96DCF F7099E9C F91123C0 2725B99F C150043E 08674928 5220972D 1A216E13 53 quit license udi pid xxx sn xxx ! ! vtp domain local-1-ir829 vtp mode transparent username admin privilege 15 password 0 xxx ! redundancy ! ! ! ! ! controller Cellular 0 lte failovertimer 5 lte modem link-recovery disable ! vlan 2-3,10,555 ! ! ! ! ! ! ! ! ! ! ! interface GigabitEthernet0 no ip address shutdown ! interface GigabitEthernet1 no ip address ! interface GigabitEthernet2 no ip address ! interface GigabitEthernet3 no ip address ! interface GigabitEthernet4 no ip address ! interface Wlan-GigabitEthernet0 no ip address ! interface GigabitEthernet5 ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly in duplex auto speed auto ipv6 enable ! interface Cellular0 ip address negotiated encapsulation slip dialer in-band dialer idle-timeout 0 dialer string lte dialer-group 1 ipv6 address autoconfig ! interface Cellular1 no ip address encapsulation slip ! interface wlan-ap0 no ip address ! interface Vlan1 ip address dhcp ! interface Async0 no ip address encapsulation scada ! interface Async1 no ip address encapsulation scada ! ! ip forward-protocol nd ! ip http server ip http secure-server ! ip nat inside source static tcp 192.168.1.6 8443 interface Vlan1 8443 ip nat inside source list 1 interface Vlan1 overload ip nat inside source list NAT_ACL interface Vlan1 overload ip nat inside source static tcp 192.168.1.6 22 interface Vlan1 2222 ip route 0.0.0.0 0.0.0.0 192.168.0.1 ip ssh rsa keypair-name SSH ip ssh version 2 ! ip access-list standard NAT_ACL permit 192.168.0.0 0.0.255.255 ! dialer-list 1 protocol ip permit dialer-list 1 protocol ipv6 permit ipv6 ioam timestamp ! ! access-list 1 permit any access-list 100 permit ip any any ! ! ! control-plane ! ! ! vstack ! line con 0 stopbits 1 line 1 2 stopbits 1 line 3 script dialer lte no exec transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh line 4 no activation-character no exec transport preferred none transport input all transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh line 8 no exec transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh line 1/3 1/6 transport preferred none transport output none stopbits 1 line vty 0 4 exec-timeout 0 0 privilege level 15 password abc123 transport input telnet ssh ! no scheduler max-task-time no iox hdm-enable iox client enable interface GigabitEthernet5 no iox recovery-enable ! ! ! ! ! ! ! end
And here's the NAT rules and interface details:
IR800#show ip nat translations Pro Inside global Inside local Outside local Outside global tcp 192.168.2.2:2222 192.168.1.6:22 --- --- tcp 192.168.2.2:8443 192.168.1.6:8443 --- --- IR800#show ip int br Interface IP-Address OK? Method Status Protocol GigabitEthernet0 unassigned YES NVRAM administratively down down GigabitEthernet1 unassigned YES unset up up GigabitEthernet2 unassigned YES unset down down GigabitEthernet3 unassigned YES unset down down GigabitEthernet4 unassigned YES unset down down Wlan-GigabitEthernet0 unassigned YES unset up up Async0 unassigned YES unset up down Async1 unassigned YES unset up down GigabitEthernet5 192.168.1.1 YES NVRAM up up Cellular0 unassigned YES NVRAM up up Cellular1 unassigned YES NVRAM down down NVI0 192.168.1.1 YES unset up up Vlan1 192.168.2.2 YES DHCP up up wlan-ap0 unassigned YES NVRAM up up
IOX host list detail:
IR800#show iox host list detail IOX Server is running. Process ID: 332 Count of hosts registered: 1 Host registered: =============== IOX Server Address: FE80::E20E:DAFF:FE8B:FFCC; Port: 22222 Link Local Address of Host: FE80::1FF:FE90:8B05 IPV4 Address of Host: 192.168.1.6 IPV6 Address of Host: fe80::1ff:fe90:8b05 Client Version: 0.4 Session ID: 1 OS Nodename: IR800-GOS-1 Host Hardware Vendor: Cisco Systems, Inc. Host Hardware Version: 1.0 Host Card Type: not implemented Host OS Version: 1.7.3.1 OS status: RUNNING Interface Hardware Vendor: None Interface Hardware Version: None Interface Card Type: None Services: =============== Service Name: Secure Storage Service Service Status: RUNNING Session ID: 2 Service Name: Host Device Management Service Service Status: DISABLED Session ID: 0
Any idea what i'm doing wrong?
Solved! Go to Solution.
06-13-2019 04:30 AM - edited 06-13-2019 04:31 AM
Hi wheres the IP NAT outside in the running config?
Looks like a good doc to follow
https://community.cisco.com/t5/cisco-iox-documents/iox-configuration-on-ir829/ta-p/3619134
06-13-2019 11:53 AM
Thanks Mark, that was the only thing missing.
Much appreciated!
