Enabling Logging to SysLog
Islam Nadim
Hello All,
     I've downloaded 3CDaemon and actually, I adore it .. Now, I need to enable the SysLog and let all devices on the network dump the logs on it.
I have 2 Routers, 2 Switches, 2 APs and 20 IP Phones. Which of these devices can communicate with the SysLog Server? And how to achieve that?
Thanks!
Prasan Venky
Level 3
Level 3
Basically syslog configuration is very easy with logging host x.x.x.x. But more options that you need to be aware of.
1)Router# configure terminal--Enters global configuration mode.
2)Router(config)# service timestamps type datetime [msec] [localtime] [show-timezone]--Instructs the system to timestamp syslog messages;
3)Router(config)#logging host--Tells the syslog server by IP address or host name; multiple servers also can be specified.
4)Router(config)# logging trap level--severity level. The possible values for level are as follows:Use the debug level with caution, because it can generate a large amount of syslog traffic in a busy network
Emergency-0
Alert-1
Critical-2
Error- 3
Warning- 4
Notice- 5
Informational- 6
Debug- 7
Router# show logging--Showslogging configuration.
Thanks for the reply. I will apply the config on one of my devices and monitor the syslog and will comeback to you.
For the debugging level, is it better to have it 4 or 5?
Router#conf t
Router(config)#service timestamp type datetime msec
Router(config)#logging host 10.10.10.10
Router(config)#logginh trap level-security 4
Is the above correct?
Check this link out for more details.
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_09.html#wp1015177
--Pls rate if this was helpful--
