09-18-2018 05:49 AM
hi,
How many net flow destinations can be configured on Cisco Router?
we already have 2 Net Flow configured, one for Solar Winds and another one for logrhythm can i add third , what will the impact to router resources..
need your support..
Solved! Go to Solution.
09-18-2018 01:03 PM
You can enable them also you can use cache, please refer below document.
https://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/12s_mdnf.html
but i compare with exiting load vs after enabling new flow..and keep monitor until it stable and expected results.
again depends on model you deploying.
09-18-2018 01:03 PM
