Enquiry on Cisco One Energy Management Perpetual license
jimmychia
Hi all,
i am going to purchase a C1-CISCO4351/K9 router, under subline there is a C1-EGW-200-K9.
May i know what is this part for?
what is mean by 200 DO end points?
Can i buy C1-EGW-100-K9 instead?
how to chose between 100 and 200?/ how to determine if i need 100 or 200?
Gary Geihsler
Level 4
Level 4
It looks like the CCW no longer includes C1-EGW-200-K9 but includes C1-EGW-100-K9 with the Foundation license. The data sheet http://www.cisco.com/c/en/us/products/collateral/software/one-wan/datasheet-c78-733012.html also indicates 100 licenses for Cisco Energy Management. If you wanted more than the 100 included in the Foundation license you can choose more in the router config via ENERGY-MGT-200-K9 and ENERGY-MGT-500-K9. I looked for a cached version of the data sheet that would show the 200 license SKU you mention and could not find one. You will choose the license based on the number of endpoints you need to use in the Energywise solution for advanced energy management. Thanks.
