EoS/EoL hardware report problem on LMS 3.2 RME 4.3.1
tim.cooper
Trying to run EoS/EoL RME reports for the first time and having problems. I have applied latest patch for CSCte717641 and this seems to have made things a little better. Originally the hardware report simply failed, but now it seems to run, but never finish. To avoid any download problems, I have manually downloaded both the EOX_SOFTWARE.ZIP and the PSIRT_EOX_OFFLINE.txt, which I have placed into the "NMSRoot\rme\jobs\inventory\reports\EOX_PSIRT\local_xml" folder. The PSIRT file has been un-compressed and put in as .txt and the EOX file has been left as a .zip. Now the report starts running, I can see it creating a temp folder in the above folder and it seems to place two files in there eos_card and eos_device, but then it appears to delete the temp folder and the job just sits at running?
Any advice would be appreciated
8 Replies 8
tim.cooper
Forgot to mention that the EoS/EoL software report runs fine
Kindly share invreports.log from location CSCOpx\Log.
Note :- Kindly remove any sensitive information before posting the log here.
Gaganjeet
This is from the time I ran the report.
[ Fri Feb 18 12:03:15 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,383,InventoryReportsAction Getting request params : ReportNAme: EoS/EoL Hardware ReportApp Name : null
[ Fri Feb 18 12:03:15 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,392,Action of Filter is null
[ Fri Feb 18 12:03:15 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,911,Generate report Request from UI
[ Fri Feb 18 12:03:17 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.ui.action.InventoryReportsAction,perform,1320,Update user given cisco.com credentails
[ Fri Feb 18 12:03:17 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.util.IRJobUtil,persistJob,201,new folder created for storing the job
[ Fri Feb 18 12:03:18 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.custom.IRCrtmImpl,getCrtList,45,called getCrtList to get list of Inventory Custom Templates
[ Fri Feb 18 12:03:18 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.custom.IRCrtmImpl,getCrtList,51,Connection is not null
[ Fri Feb 18 12:03:18 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.custom.IRCrtmImpl,getCrtList,70,Number of templates returning: 2
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,,246,
Starting the JOB 3972
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1506,
Getting the job details from persisted Job
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1528,
Job Details : EoS/EoL Hardware Report
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1530,
Job is custom report : false
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1532,
Job runtype : Immediate
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1534,
Job date : 18-2-11 12:10
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1536,
Job description : test99
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1538,
Job E mail id :
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1540,
Job publish location :
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1542,
Job template id : 0
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1544,
Job job id : 3972
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,populateJobData,1562,
All the report properties read successfully from the job.
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,61,sun.misc.Launcher$AppClassLoader@92e78c
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,203,
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,294,
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,314,
Valid License.
Proceeding with job execution.
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,334,
Running Report job 3972 instance id 0
[ Fri Feb 18 12:03:19 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,354,inside devsel flow
[ Fri Feb 18 12:03:27 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,558,normal3
[ Fri Feb 18 12:03:28 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,600,successfully got predeployed devices
[ Fri Feb 18 12:03:28 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,runReport,606,submitted.length3
[ Fri Feb 18 12:03:29 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,generateReportData,1633,************before set device in gen rep data**********
[ Fri Feb 18 12:03:29 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,generateReportData,1639,************after set device in gen rep data*******
DEBUG,2011-02-18 12:03:32,250,Datagenerator class name is class com.cisco.nm.rmeng.inventory.reports.datagenerators.EOS_EOL_RDG
DEBUG,2011-02-18 12:03:32,250,Datagenerator class instance is com.cisco.nm.rmeng.inventory.reports.datagenerators.EOS_EOL_RDG@1107304
[ Fri Feb 18 12:03:33 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.db.DatabaseConnectionPool,getConnection,113,Inside ICSDatabaseConnection, MAX_COUNT =5
[ Fri Feb 18 12:12:40 GMT 2011 ],ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,getFileName,545,Here *****eox_card.xml
[ Fri Feb 18 12:12:44 GMT 2011 ],ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,getFileName,545,Here *****eox_device.xml
NOTE:
I can see both files in the NMSRoot\CSCOpx\files\rme\jobs\inventory\reports\EOX_PSIRT path, but not in the local_xml directory?
Then nothing for an hour and then the following that I don't think id related?
[ Fri Feb 18 13:18:58 GMT 2011 ],INFO ,[TP-Processor3],com.cisco.nm.rmeng.inventory.reports.ui.action.IRJobsAction,getArchiveId,387,Entering the method
[ Fri Feb 18 13:18:59 GMT 2011 ],INFO ,[TP-Processor3],com.cisco.nm.rmeng.inventory.reports.datagenerators.SystemReports,goForPDFReport,308,Device Limit is = 750
[ Fri Feb 18 13:18:59 GMT 2011 ],INFO ,[TP-Processor3],com.cisco.nm.rmeng.inventory.reports.datagenerators.SystemReports,goForPDFReport,309,Device Limit for Device Statistics Report is = 750
INFO ,2011-02-18 13:18:59,281,export device list from request [Lcom.cisco.nm.rmeng.util.datastructures.DeviceID;@1db810a
[ Fri Feb 18 14:16:17 GMT 2011 ],INFO ,[TP-Processor5],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,61,WebappClassLoader
delegate: false
repositories:
/WEB-INF/classes/
----------> Parent Classloader:
org.apache.catalina.loader.StandardClassLoader@1a06e38
[ Fri Feb 18 14:16:17 GMT 2011 ],INFO ,[TP-Processor5],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,126,INFO: Resource Limit from License file=10000
[ Fri Feb 18 14:16:17 GMT 2011 ],INFO ,[TP-Processor5],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,203,
[ Fri Feb 18 14:20:00 GMT 2011 ],INFO ,[TP-Processor16],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,61,WebappClassLoader
delegate: false
repositories:
/WEB-INF/classes/
[ Fri Feb 18 14:20:00 GMT 2011 ],INFO ,[TP-Processor16],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,126,INFO: Resource Limit from License file=10000
[ Fri Feb 18 14:20:00 GMT 2011 ],INFO ,[TP-Processor16],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,203,
[ Fri Feb 18 14:23:03 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.custom.IRCrtmImpl,getCrtList,45,called getCrtList to get list of Inventory Custom Templates
[ Fri Feb 18 14:23:04 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.custom.IRCrtmImpl,getCrtList,51,Connection is not null
[ Fri Feb 18 14:23:04 GMT 2011 ],INFO ,[TP-Processor9],com.cisco.nm.rmeng.inventory.reports.custom.IRCrtmImpl,getCrtList,70,Number of templates returning: 2
at that point I cancelled the job as it had been running for two hours for 5 devices.
Kindly clear the contents of this file and then reproduce the issue. Kindly dont wait for 6 hours to complete the job, just upload the complete log and not few instances from log after running the job for 2 hours.
Gaganjeet
Hi Gaganjeet,
Please see attached. This time I did not stop the report and left it running for 4hrs, but it still has not stopped and the job appears frozen?
Sorry forgot to mention that the job log info starts from 14:38.
The job started at
[ Sat Feb 19  14:48:23 GMT 2011 ],INFO ,[main],com.cisco.nm.rmeng.inventory.reports.job.JobExecutor,,246,
  Starting the JOB 3982
and the last activity reported is :-
Sat Feb 19  14:49:32 GMT 2011 ],ERROR,[main],com.cisco.nm.rmeng.inventory.reports.util.LocalXMLParser,getFileName,545,Here *****eox_device.xml
Kindly change the option from Off Line mode to Cisco.com from RME > Admin > Report > PSIRT\EoX Reports and then enable the debugging as per below steps :-
RME>Admin>System Preferences>Application Log Level Settings > Application > InvReports.
Reproduce the issue and share the new invreports.log.
Note :- Turning debug on for this application might contain sensitive data into debug logs. Kindly remove it
and share the complete debug log.
Gaganjeet
Sorry been out of the office for yesterday, have set the logging level and changed to Cisco.com mode and
just waiting for the download to complete. If I run the report at the moment its empty? I guess this is because the download of the
file has not completed yet?
