Error Archive_Daily Cisco WLC
Nadia Bbz
Dear Team ;
after upgrade cisco wlc from 8.5.131 to 8.5.161, i get error of archive daily in cisco prime ( failed to get configuration from device , device is in encrypted mode ) , how to disable this mode from controller
thank you in advance
finally i found the solution
from cisco prime -> network device -> controller -> configuration tab -> security -> uncheck file encryption
as show in the pictures below
i don't know why this parameter don't appear , when i access  directly to the controller via HTTPS
7 Replies 7
Mark Elsen
 - You also need to check , if the Prime version being used , still supports this new controller release If not it could be that  you need to upgrade Prime :
            https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
 M.
refer to the document all version of cisco wlc 3504 is supported by cisco prime 3.4
 - Try to remove the controller from Prime , and then re-add it afterwards. Check if the problem persists. But before re-adding also press Verify Credentials , to make sure that all given credentials are working. Also leave a bit of time between the 2 operations.
 M.
Before remove controller from prime , i compared the configuration before upgrade with after upgrade
as show in attached file the configuration added doesn't affect the backup
after remove and re-added the wlc the issue persists
 - As far as I see it you have 2 options : 1) Either escalating towards TAC    2) Provided 'sufficient time and interest' - if your Prime  servers runs in a virtualization-supporting environment , it is sometimes easy to clone the Prime-host and for instance, upgrade the clone to the latest Prime release (preferably with latest patch installed too) and verify the problem again.
 M.
i have a physical appliance cisco prime , i haven't service contract to download software
thanks for helping me
