%Error computing MD5 hash tftp (Connection timed out)
san ju.
Error while verifying MD5 checksum of a file and also for copying files from TFTP to bootflash.
Address or name of remote host []? 22.14.8.5
Loading iosxe-utd.17.06.01a.1.0.7_SV2.9.16.1_XE17.6.x86_64.ova from 22.14.8.5 (via GigabitEthernet4.503): !...!....!....!.... [timed out]
%Error computing MD5 hash tftp://22.14.8.5/iosxe-utd.17.06.01a.1.0.7_SV2.9.16.1_XE17.6.x86_64.ova (Connection timed out)
- Using TFTPD64.
- Pinging from both successful.
- Configured source interface for TFTP!.
any help would be appreciable.!
thanks.
5 Replies 5
balaji.bandi
what device is this ? How far is the TFTP ? same network ?
how big is the OVA file ?
worth increasing block size other option and test it.
(config)#ip tftp blocksize 8192
BB
san ju.
Tried block sizes, the problem is still there!.
Its CSR1000v, It is in the same network!
File size - 140MB
Actually device is in 17.x IOS
It was working when i tried to do that verification on other router(which is running 16.x.x) on this same TFTP.
 it is happening only on this!.
what is the difference ? working vs not working ?
BB
san ju.
Hi balaji,
My apologies, I made a typing error,
 Any assistance would be greatly appreciated.
thanks.
what is the full syntax for your TFTP transfer ? You could try and set the source interface to the management interface and then use the syntax below:
copy tftp://22.14.8.5/iosxe-utd.17.06.01a.1.0.7_SV2.9.16.1_XE17.6.x86_64.ova bootflash: vrf Mgmt-intf
Also, where did you get the .ova file ?
