ā03-29-2023 04:32 AM
Hi all,
I am having issues when attempting to configured Radius please see below..
L1N5K02-P# conf t
Enter configuration commands, one per line. End with CNTL/Z.
L1N5K02-P(config)# no fips mode enable
FIPS mode is disabled
L1N5K02-P(config)# radius-server host 10.200.103.112 authentication accounting
FIPS cannot function with RADIUS(MD5) enabled
Disable FIPS if using RADIUS(MD5)
L1N5K02-P(config)# aaa authorization ssh-publickey default group RADIUS1 local
aaa function not supported by configured method
could not update aaa configuration
L1N5K02-P(config)#
ā03-29-2023 04:40 AM
1. configure terminal
2. no fips mode enable
3. exit
4. (Optional) show fips status
5. copy running-config startup-config
6. reload
I think you need to reload tio disable FIPS
ā03-29-2023 06:36 AM
switches have fips disabled and been reloaded still showing error
L2N5K01-P# show fips status
L2N5K01-P#
L2N5K01-P#
L2N5K01-P#
L2N5K01-P#
L2N5K01-P# conf t
L2N5K01-P(config)# radius-server host 10.200.103.112 authentication accounting
L2N5K01-P(config)#
ā03-29-2023 09:50 AM
- Might be a bug use latest https://software.cisco.com/download/home/283757883/type/282088129/release/7.3(11)N1(1) , if applicable , check if that can help ,
M.
