Ethernet and Fastethernet connection
leeyuetfoong
When I issue show log command i saw a lot of the following error message
Nov 28 03:16:57.079 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on Ethernet0/0 (not full duplex), with GZOFF-24AREA01.china.nokia.com FastEthernet0/4 (full duplex).
Nov 28 03:17:57.086 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on Ethernet0/0 (not full duplex), with GZOFF-24AREA01.china.nokia.com FastEthernet0/4 (full duplex).
Nov 28 03:18:57.090 UTC: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on Ethernet0/0 (not full duplex), with GZOFF-24AREA01.china.nokia.com FastEthernet0/4 (full duplex).
but when i check my Ethernet 0/0 is actually set to full duplex.
gv-rtr11#show run
interface Ethernet0/0
ip address 172.28.68.2 255.255.255.0
ip access-group WORM_PROTECTION in
ip access-group WORM_PROTECTION out
ip accounting output-packets
load-interval 30
full-duplex
service-policy input marking
traffic-shape group 80 256000 7936 7936 1000
standby 1 ip 172.28.68.1
standby 1 preempt
gv-rtr11#show clo
03:31:43.781 UTC Mon Nov 28 2005
can anyone tell what happen ???
best regards
Lee
5 Replies 5
nhabib
Level 9
Level 9
What about FastEthernet0/4 on GZOFF-24AREA01.china.nokia.com?
Does it also say "full-duplex" in the config?
I'm not sure because i don't have access to the switch. but can we trust the error message? since the error message give us the wrong information on the Ethernet0/0, should be full duplex.
according to the error message the Fastethernet0/4 should be in full duplex mode
thanks for your reply
best regards
Lee
I suspect that the other side is not set to full duplex, but possibly auto
spremkumar
Level 9
Level 9
Can you hardcode the duplex to full in the remote fastethernet 0/4 and check for the logs ?
If you are still getting the error logs would suggest to change the duplex in the ethernet0/0 to half and also in fastethernet 0/4 and verify ??
regds
Fastethernet0/4 already in full deplex mode as stated in the error log
best regards
Lee Yuet Foong
