Expect Scripts for Cisco routers
aadeoye
Does anyone know where I can get Expect scripts for Cisco routers.
I read in an article that there were a few on Cisco's FTP server but I was not able to find anything.
Thanks in advance for your help.
yjdabear
Here's the only Expect script I find on cisco's site, for CatOS no less:
http://www.cisco.com/warp/public/477/SNMP/move_files_images_snmp.html
To paraphrase a post I saw somewhere recently: Before you look for Expect, check out Rancid: http://www.shrubbery.net/rancid/.
Incidentally, I'm [almost] done writing an Expect script to pull IOS configs (still have an undiagnosed problem with CatOS) via telnet/SSH without having "copy running [tftp|scp|ftp|etc.]" command authorization.
I will have a look at Rancid as well.
Apparently, about 4 years ago, the following scripts were on ftp.cisco.com: ciscologin (for loading router names and passwords from a file), ciscoexec (feeds EXEC commands to routers via TELNET) and ciscoconfig (configures routers).
Are these still available?
Weird, I can't find them either.
