Showing results forĀ
Search instead forĀ
Did you mean:Ā
Exporting csv reports to repository
lni1
Dear Cisco Guru's,
We are currently testing Prime infrastructure 2.1. Is it possible to export CSV reports to an external repository ??
Apparently, Repository path points only to localdisk/ftp
What is told in the 2.1 pi admin book :
Off load backups and reports—You can save space on the Prime Infrastructure server by saving reports and backups to a remote server.
Many thanks,
Lieven Stubbe
Belgian Railways
Vinod Arya
This is correct, it has options for local disk and FTP because, currently PI supports NFS and FTP/SFTP.
NFS is usually mapped/linked/mounted on one of the local directory and hence you need to select that local directory which is linked to NFS server.
For details check document for Configuring the NFS backup Server.
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
