Showing results forĀ
Search instead forĀ
Did you mean:Ā
F5 and Ciscoworks
alkabeer80
I have BigIP F5 load balancer and i need it to send snmp traps and syslog messages to ciscoworks, Can i do it?
Do i need to do any thing extra on ciscoworks? what is the MIB used?
thanks
Joe Clarke
No, this will not work.  Syslog and fault management in LMS does not work with non-Cisco devices.  What you can do is add your load balancer into LMS and get basic MIB-II inventory from the device.  Additionally, if you have Health and Utilization Monitor, you can do general availability and MIB polling of the F5.
Hi, if i want to add it manually, should i go to RME and add new device with the same community ?
I have checked my load blancer and it needs OID ? from where i can get it?
thanks
Assuming LMS 3.x, go to Common Services > Device and Credentials > Device Management and add your load balancer there.  You do not need to specify the sysObjectID.  Leave it as UNKNOWN, and LMS will find the right value.
