Showing results forĀ
Search instead forĀ
Did you mean:Ā
Fiber optic media converter up and down periodically
joseph.sailo
The internet connected to a client has this following problems, it is connected both sides by media converter
  • the internet connection is up during morning hours and without any reason its down by afternoon hours
  • the one end is connect to switch via media converter and vice versa
what can be the reason for this period-icily up and down of the internet connectivity
marce1000
         - Contact your service provider  and report the issue
M.
Start troubleshooting by replace M/C on the near end.
In my practise faulty media converters were causing very strange and absurd problems.
D_Lebedev  Thank you for the advise.. will look into your advise
marce1000  Thank you for the reply
