Frame Relay Problem
shiva13
I wanted to configure Frame Relay.  I have 3 networks.
192.168.1.0 network and 192.168.3.0 network can communicate each other but 192.168.1.0 network and 192.168.5.0 network can not communicate each other.
They could communicate in my last try. I do not know what changed.
The configuration of Router0
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX152430AA-
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
no ip address
encapsulation frame-relay
interface Serial0/0/0.100 point-to-point
ip address 10.11.1.1 255.255.0.0
frame-relay interface-dlci 100
clock rate 2000000
interface Serial0/0/0.101 point-to-point
ip address 10.10.1.1 255.255.0.0
frame-relay interface-dlci 101
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.5.0 255.255.255.0 10.11.1.2
ip route 192.168.3.0 255.255.255.0 10.10.1.2
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
The configuration of Router1
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524K7OH-
ip address 192.168.5.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 10.11.1.2 255.255.0.0
frame-relay interface-dlci 102
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.1.0 255.255.255.0 10.11.1.1
line con 0
line aux 0
line vty 0 4
login
end
The configuration of Router2
version 15.1
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX15244E52-
ip address 192.168.3.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 10.10.1.2 255.255.0.0
frame-relay interface-dlci 103
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 192.168.1.0 255.255.255.0 10.10.1.1
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
4 Accepted Solutions
balaji.bandi
make sure the interface up, and post the below output :
show frame-relay pvc
show frame-relay route
show frame-relay map
BB
On the router1 is the Gig0/0 interface up ?
From PC are you able to ping  192.168.5.2  ( from router 1 are you able to ping PC IP  192.168.5.1)
check any firewall in the PC ?
BB
I forgot to give pc1 an ip address.
I apologize, i wasted your time.
thats all right, can we mark this as resolved, if all is good.
BB
5 Replies 5
balaji.bandi
BB
I tried pinging from 10.11.1.2 to 10.11.1.1. They can ping each other.
Router0
Router#sh frame-relay pvc
PVC Statistics for interface Serial0/0/0 (Frame Relay DTE)
DLCI = 100, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0/0.100
input pkts 14055 output pkts 32795 in bytes 1096228
out bytes 6216155 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 32795 out bcast bytes 6216155
DLCI = 101, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0/0.101
Router#sh frame-relay map
Serial0/0/0.100 (up): point-to-point dlci, dlci 100, broadcast, status defined, active
Serial0/0/0.101 (up): point-to-point dlci, dlci 101, broadcast, status defined, active
Router1
DLCI = 102, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0/0
Serial0/0/0 (up): ip 10.11.1.1 dlci 102, dynamic,
broadcast,
CISCO, status defined, active
BB
BB
