SNMP on 9000 switches
benolyndav
Level 4
Level 4
Hello
We currently pointing our 9000 switches at DNAC for snmp, Is it possible to add another SNMP destination on the 9000 switches so they would send to 2 destinations.??
balaji.bandi
For SNMP query any device can query cat 9K switch as long as community information and ACL(if you made any to match with the I)
SNMP traps  - you can send different destinations :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-11/configuration_guide/nmgmt/b_1611_nmgmt_9300_cg/configuring_simple_network_management_protocol.html
BB
balaji.bandi
BB
