FTD
amaresh_22jan
Frequent Visitor
Frequent Visitor
Hi All,
Attached is the diagram for the refence,
Diagaram is as follows
Two router - One each router one ISP link is terminated , Each ISP has provided 8 public IP which is required from design and Natting prospective.
Two FTD firewall- For Natting , Site to site VPN config , IPS  configuration etc
Two WAN switch (Stackable) - For design purpose - Connecting Routers , Firewall .
TWO ASA firewall- Design only for Remote access VPN.(VPN ConcentaratoR)
Two core switch-connecting FTD
The main objective is to obatin redudancy on each level. --- Router , FTD , WAN Switch , ASA , coreswitch
Also I would like to know whether the FTD  needs to be clusted or Configured in Active/Standby.
Kindly Note - Natting  for the LAN tarffic needs to be configured on FTD. , If the Primary Router/Link goes down then the Public IP from secoundary IP needs to be utilised for Natting purpose..
Kindly suggest design with config .
balaji.bandi
We are not have information what model of FTD you going to deploy. Hope both FTD will in same location.
here is the refernce and best use cases :
https://www.ciscolive.com/c/dam/r/ciscolive/latam/docs/2017/pdf/BRKSEC-2050.pdf
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/clustering/ftd-cluster-solution.html
https://www.cisco.com/c/en/us/td/docs/security/firepower/620/configuration/guide/fpmc-config-guide-v62/firepower_threat_defense_high_availability.pdf
BB
FTD 2210, It wil be in same location. Whether suggested design will work keeping FTD in cluster mode and ensuring the high vaiability as mentioned
High level your design should work. let us know any further asistance required, follow HA guide lines as per previous post.
BB
